I have been unable to register the purchase of my PS5 Disc Version, to My Sony account here in the UK. I have typed in the model number :- CFI-1016A, but i am unable to progress any further on Registering A New Product section, i.e:- Did you buy online?, Name of store, Purchase date, etc. I have tried using different browsers, different devices, mobile, laptop, ipad, but nothing seems to work!! Has anyone else had this problem? Any solutions to rectify this?
Yes, I have the exact same problem.
Try without the " - "
Thanks Marino for your reply. I tried that before i posted, & nothing seems to work. I think the site isn't working properly, & doesn't recognise the model number of the PS5 (Disc Version) CFI-1016A
Sorry, I read quickly and I confused the "abbreviation" with another product, even if you wrote PS5.
I don't think there is a way to register a PS5 in Sony Electronics.
You can activate or deactivate your console from the
following setting.
Go to [Settings]> [Users and Accounts]> [More]>
[Console sharing and offline playback],
then select [Enable] to activate or [Disable]
to deactivate.
Hey keclark86, PS devices have a different website for registration, try contacting PS support to know the right one. Or try linking your accounts if you already have a PS account.
Thank you Hannah, i will try to contact them.
Thank you, everyone explained in detail.
Ps5 registration is done through playstation network and is a fully automated process.
When you connect to the psn the console is registered to your account.
You can view your registered devices by going to:
https://www.playstation.com/en-gb/support/hardware/
Sign in and the click on your profile then select account settings.
At the bottom you will see "device management"
Your playstation devices are in there
