I can put in the model number, but it won't let me put in the Purchase Details in order to proceed. Am I missing something here, or is the Register My Product not working?
Hi.
I'm having the same problem.
I bought Sony Bravia KD-43XE7077 , but when i try to register it, I can't access to the purchase details in order to proceed , nor can I find my tv when i try to search for my tv manually.
Please help me
I am also having the same problem for a portable speaker and walkman. Let's hope Sony check this and correct the problem.
I cannot register my A6000 camera.
It will not even accept the model number when I type it in.
Very frustrating - spent the last 45 minutes unsuccessfully trying to register my product before coming across this thread. Expect better from Sony.
Can't register my KDL-32WD756. Frustrating.
Wake up Sony !!
Just logged in this morning to find that all the products which I had registered previously are not showing, so maybe the problem is not just for new registrations.
Same here and I posted in a different thread
You are right I fear, The problem isnt just for new registrations and hopefully Sony will fix this
Doh - I just went back and its there again so ive taken screen shots. I clicked on the countdown thing for CES just prior to this so maybe give that a try folks?
Hi, I had the same problem when using the Chrome browser to access the website. After a very quick and helpful Community post from @jumpsuit reply I used Safari instead and I could find my model and register with no further problems. Give it a try to see if it also works for you as well
