I have bought a second hand rdr dc100 DVD/Hdd recorder and I was just wondering as it didn't come with original remote control, can you record from DVD to hdd as I have in the past copied TVs prog that I want to put on to device to edit commercials out. Is this pnossible as I don't have a manual thanks
Hi LynnK007
You can find the steps to dubbing programs from a disc to the HDD on page 71 of the manual here: https://www.sony.co.uk/electronics/support/res/manuals/4131/41319781M.pdf
Win_88
Hi Lynn,
I've included the link to manual for your model here.
Hope that helps.
Best wishes,
Sean Mc
Hi LynnK007
Win_88
Hi LynnK007,
Are the discs copy right protected?
Cheers,
The_Black_Rose
I don't think so, it was recorded from my friends machine. She hasn't used it for a while so she may have pressed the copywrite button by mistake
thanks for your help
Hi LynnK007,
I believe that the discs have to have no copy right protection and they've to be finalized. Does this happen when you try any other discs?
Cheers,
The_Black_Rose
