HI
I have just bought a PS4 to relace my PS3. Now I understand the PS4 is not compatable with my G27 wheel
I have not yet opened the box, so before I do can anyone discuus this with me. Is it a rumour or fact? Is there a download or modification or any workaround that will get these two bits of kit working together?
Graham Smith
Hi @grasmith95 and welcome to the UK Community
Judging by what I've read online the answer is yes and no
Have you read this article which may give you some idea?
Unfortunately we don't cover Playstation on this forum so you're probably best
posting on the Playstation forum Here where someone may have some more detailed info for you.
Hope this helps.
Hi
Thanks for your reply
There is a bit of kit to make the g27 connect like a g29 but it cost £50. I cannot find a comment from anyone who used it
I will have to give up, or buy another wheel
Graham Smith
Hope this helps.
