Hello @yotaree,
if you have been invited to the product tester program by Sony, you will be informed via email as soon as there is a new "round".
- Nic
Got an email from Sony saying they are sending the product I requested, any ideas on how long it takes v after that??
Hello @yotaree,
- Nic
good post thnaks
Sony will invite you themselves if you've already applied.
Be active and provide feedback for Sony products and one day you will join in !!!
Cheers.
how do you become a product tester
I have tested one product but have not been contacted about any othere items.
Can I submit a review.
Hello mate, how long does it take for a product chosen by a product tester to arrive?
Hi @yotaree
It depends, for larger items you will get a notification but for smaller ones you won't.
What have you been asked to test?
A 55 inch television
