Hi All, I have a Sony DVP-CX850D (200)Disc Player, the problem I am having is now twice the same thing has happen on two different machine's, I tried to turn it on either by the remote or the player, it turns on for about 3-5 seconds then turns off. It's a common fault so I have been told, but no one has come up with a solution to fix it. Has anybody else had the same problem and is there a fix. Hoping for some good news.
Many Thanks
A1Foxxy123
Hi A1Foxxy123, did you try unplugging from the mians and all these basics?
Hi HannahEd01, Yes and Yes
A1Foxxy123
Hey, if the issue is happening even after a factory reset, try sending it for repair.
