Hi there.
Is there anyone as knows what navigation box is compatible with monitor XVM-F65WL and connection box XA-126.
There is a 8 pin RGB connector on connection box where to connect the module (GPS).
I´w spent hours of trying find out ,mailed to sony support but they have no idea.
Thanks/L-G
That's a pretty old device! What are you trying to accomplish here? Maybe I can help?
I´m using it as reverse camera but it would be nice if it can be used as a navigator (GPS) also.
I can`t find a navigation module that`s compatible with the XA-126 connection box.
Thank`s/L-G
Hey Stinky111, I'm not sure if I can help, maybe someone who has the knowledge of this device can help you.
Hi there.
OK but thank's för showen interest , perhaps someone out there havet an idea.
@ Stinky111, best wishes, If not try contacting Sony directly.
Already done ,wrote it in my first post
Thanks/L-G
@ Stinky111, what did they tell you?
Hi there.
Their suggestion was that i should contact the "eetgroup" so i sent an e-mail
and they told me to contact (eet.se) and their suggestion was to (because i was a consumer) contact
an another local dealer in sweden but they could`t find anything supported.
Thanks/L-G
Hi @Stinky111, out of curiosity were you able to find the compatible parts for it at Sony authorized dealers?
