Good Afternoon all
Several forum members have contacted me now, and thought id create this thread to explain to the others who are have problems.
Some of you may be experiencing this message when logging on to your MySony Account in order to use these forums:
Upon validating the email address, you might get this:
Unfortunately this is a known issue for some people. A support ticket has been raised in Sony's technical department to resolve this, but unfortunately it is not fixed as of yet.
When it is, ill post back. In the mean time, either sit tight, or if you have an email from a subscribed thread, you can reply to that email to post on that particular thread.
Just closing this thread off now, as its confirmed to be resolved.
Hi all
As an update, unfortunately nothing has changed and hence not resolved as of yet.
Hello all
Latest progress:
Let me please re-iterate, no account information has been hacked, lost, stolen or otherwise. This is purely a technical fault on Sony's end.
Thank you for your continued patience.
Hello all
A couple of people have confirmed that they can now log in to MySony and hence these forums, where they could not do so before.
But no confirmation from Sony to indicate that its fixed as of yet,
I'm back....
