Told to contact local support centre to be able to chnge my user name but where and how do I find my local support centre? All I want to do is change my User name, should take so much time and be so difficult.
You can't change your user name yourself but if you let me know what you would like to change your Sony Community User Name to I'll try to get someone to do this for you..
@Thalamus. wrote:
Hi @carolyngyseman,
just checking if you still want help to change your username??
i also need to change user name from a165691 to responder1 how do I contact you
Hi a165691,
I’m not as active on here as I used to be but try messaging one of the Community Team to see if they can help..
