For some reason my Bravia tv will not now load up BBC Iplayer, it was ok in the past, my wif connection is ok as Netflix works fine.
Any tips on how to fix it please 🤔
Hi there,
Which model do you have?
Best wishes,
M
HI, its a 32WD756BU model........found a simple fix yesterday and hope it has fully cured it, just removed the power plug from the wall for 30secs and iplayer came on ,weird or what !!!
Does the BBC only zap iplayer on some Sony tv's ,or on all brands after a few years , if so will not buy the brand again.
