Hi all. I'm totally new to Adobe products and trying to find some advice.
How do I deal with the Adobe Reader error message: 'Adobe Acrobat Reader has found an error it can't correct'.
It shows up for one PDF format document but not others. Why does the program give me this pop up every time?
I am using Sony Vaio T13 laptop on Windows 8
Adobe Acrobat Reader DC (15.0)
Thanks very much in advance for all your help
Adobe releases regular security updates for Acrobat Reader DC and Acrobat DC. Installing the latest updates might solve the issue.
3.Check for updates If the Updater dialog box appears, click Yes.
You may refer to this pdf recovery page or below steps to clear the App Data Cache.
Hi Reese8,
I think it's better to post this issue on the support channel of Adobe, but before that, you can make sure that you have the latest version of Adobe Reader installed on your laptop.
Cheers,
Almou_10
