How can I get Rode Stereo Videomic Pro work with Sony A6400. When the mic cable is connected to mic input there is no sound for the video.
Yes, I installed a new 9 V battery, but it was wrong way. When I turned it - it works. 🙂
Yes, I have tried the different positions of the switch in the mic (0, I, Í), but it does not help.
Hello @jyrkijluukkanen,
glad to hear you could figure out what the issue was.
I marked your last post as "solution".
- Nic
