Probably a stupid question but can you buy ebooks from uk reader store when you live in ireland?
To save time, can I suggest you look at this post ....
which will tell you most of what you need to know - it isn't a stupid question at all.
I don't really know why Eire isn't able to "use" the UK store, but suspect the reasons are tied up with copywrite/intellectual property rights etc... rather than technical ....
You can use the legal free sites though (Project Gutenburg, etc...) and buy from most anywhere else though, even from US in euros/sterling etc... - can I suggest you could sign up to"MobileForums" which will give you a lot of helpful info regarding this, and "how to..". (free to join, and secure).
They also have a vast free library of their own as well, for all members.
Another good idea is to install "Calibre" ereader management system on your PC/laptop, (again, free, and secure) - very easy to use, from all sources, and gives you a good way to compile your own library, again, for books from all sources, so no software problems, works very well with all Sony devices/models by simply plugging in.
Hope this helps
Hope this helps
