- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
My reader is only 5 months old and the side lamp does not work...
Is it normal ? How do I change it?
Do I have to pay for it?
Thank you
Michele
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello midarq - by side lamp, I presume you mean the light on a Sony cover ? A flexible arm with light that lights up when swivelled upwards to illuminate the reader page ?
It can simply be the battery needs renewing - rechargeable ones are OK, although battery life is good on these lamps. The battery is changed through a flip lid in the left side of the cover - shouldn't break your nails, it opens fairly easily !
The other reason may be the bulb needs changing - haven't done this myself, but should be standard maintainance level..... I'll have a look tomorrow.
Try the battery first anyway, it's the most likely.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hope this helps.
