- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a PRS-505 and I frequently loose bookmarks, They are OK until turning off or loading a new book then they vanish. I seem to remember that I can delete a file that gets re generated when the book is switched on that may cure the problem. Can anyone help please.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi georgina1953
It would appear you may be removing the Reader or closing the Reader Library before the XML file is updated correctly, i would recommend you do a open the directory on the Reader via Windows Explorer and find the Database folder, in there you will find the follow;
/database/cache
/database/media
/database/sync
Explorer the cache directory and delete all the XML files, this will force the Reader to re-index the media on the memory, Remove the USB cable and the unit will reconfigure the files, try a few creating a few bookmarks and then connect to PC again, copy a new file or book to the reader, ensure the 'Status' icon on the left hand bar has stopped, then remove Reader from USB cable.
I hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi georgina1953
/database/cache
/database/media
/database/sync
I hope this helps
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and thanks, I had to do it a couple of times but guess it was finger trouble on my part.
