How can I keep my Sony Reader PRS-505 safte from theft when on the beach or by the pool? Is it possible to get a lock so I can secure it to an static object>
I would love for someone to steal my awful Sony Reader. Why would you want to keep yours safe?
Hi allanahm61,
When you take your reader to the beach you may want to also consider enabling your Readers device lock..
This can be found by clicking on Settings (bottom right of your readers home page.)
Then click on System Management,
Followed by Device lock.
Pacsafe TravelSafe 100 Secure Portable Safe arrived yesterday.
Struggled a bit initially to work out how to close it ( I am not technically minded!), but once matstered it very easy to use - though the cable is a bit stiff at first. It folds up very small when not in use so can easily be carried in your hand luggage or suitcase.
Very sturdy design.
I can easily fit the Sony Reader in it with a digital camera and cash - ideal.
There are larger sizes available that are big enough for a laptop.
Excellent, glad you've found what you were looking for, I'll make a note as Pacsafe TravelSafe 100 Secure Portable Safe sound like it could be useful for when on holiday..:smileyhappy:
