How can I keep my Sony Reader PRS-505 safte from theft when on the beach or by the pool? Is it possible to get a lock so I can secure it to an static object>
How about something like this?
Hi allanahm61,
welcome to Questions & Answers..:smileyhappy:
Unfortunately there is not a security slot on the reader, so unless you wish to attach a small security plate I'm not sure how you can lock it to anything..
Only simple option could be to hide your reader in an old book or something..
great find Blencogo..
Probably only available in California though Thalamus!
Thank you, though looking a the dimensions it doesn't look quite big enough as the ereader is 7 inches by 5 inches. Has anyone seen a larger version of the beach safe please?
Just found this one that seem ideal - Pacsafe Travelsafe 100
http://www.amazon.co.uk/Pacsafe-TravelSafe-Secure-Portable-Safe/dp/B000KFYYDO
Glad you found what you were looking for..
If you decide to go ahead and purchase the Pacsafe Travelsafe 100 any chance of giving some feedback as it may be useful to others..:smileywink:
odered this mroning on amazon - will let you know when it arrives.
Thanks
