When you find a contact, and clicking on the call screen darkens and not tip into a state where the upper part of the screen and see the contacts below have hands on control and under her mam button on the hanging. Call at this moment, can not quit. Only help to dismantle the phone and SD card spot next to press the reset button and start over phone .This problem also occurs in the opposite case, when you receive a call, the moment when it turns black screen Receive again and again can not manipulate the phone. Can anyone advise me how to solve this problem. I already have a kind piece and still the same problem. thank you
Settings > about phone > diagnostics > test the phone
also is there anything blocking or partially blocking the proximity sensor?
Hello you use any screen saver ? if you use could cover the proximity sensor and that would be the problem
Thanks for your response .On the phone I have pasted protective film .Test I did, but I'm not sure if it has to be the way it was when the phone vibrate only test the zoom. On completion of the written test ok.
This process, I still practiced .While the fact that it has tanto phone only less than a week before that I had xperia x10 in this regime are unfortunately failed me for the whole lifetime to get. Certainly the time gets to him. Nevertheless, thank you very much for answer
Boot the phone on safe mode and report back, make sure to remove the protecting film
if that doesn't work then, repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
I got your message, you need to contact your Local support to further investigate this problem.
A mi Xperia se quedo la pantalla negra
To my Xperia stayed the black screen
GT
