Dear all,
I bought a D2203 two weeks ago and since yesterday every time I try to turn off the screen pushing the power button, the mobile hangs up for few seconds and it is reset (it appears the Sony, android and the PIN is requested)
If the screen turns off because no activity, I've checked the phone is on calling it. But if I press the power button to turn on the screen, the cell is reset in the same way ot happens when I want to turn off the display.
I cannot enter in safe mode, every time I push the power button the effect is the same, a reset.
Have you experienced that? How have you solved it?
Thanks in advance!
