Hi @7OKER, welcome to our forum!
I'm so sorry to hear about you losing your charger.
The charger that was included in the box together with your Xperia E4 is called EP800.
Output = 5.0VDC = 850mA (VDC=Volts Direct Current, mA=milliamps).
I recommend that you contact your Local support and see if they are able to assist you with a new charger, since it's always recommended that you charge your phone only with a original charger.
Let me know if anything is unclear or if there is anything else I can assist you with!
No problem at all!
I wish you the best of luck and let me know if there is anything else I can assist you with.
