Hi
My Sony Xperia E dual refuses to let me install applications onto the internal storage. If I go into Settings and then into Storage, it shows me three storage slots available namely: Phone memory, Internal storage and SD card. When I download an app, it would store it on the Phone memory (which has about 500 megs of space). Recently, I got a constant notification telling me that my phone was "Low on space" which doesn't make sense. Yes, the "Phone memory" is full but the "Internal storage" has 2 gigs of free space. Is there no way to force my phone to use only the "Internal storage" instead of the "phone memory"?
Kind Regards
Timothy Brunsdon
Well,it seems that it was a huge mistake to buy this model.. I am disapointed by the producer's attitude..once they 've hunted the customer they are no more interested in any help,updates etc. This is rather a short sight politics concerning the company brand. No one once disapointed will come back and will not, to put it mildly, recommend products and company to anybody..
