- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
September 2013
September 2013
its very tricky to open the bottom cover in xperia e!! fear of damaging the two clips which hold the bottom cap!:smileysad:
1 ACCEPTED SOLUTION
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2013
September 2013
You're right osk, perhaps Alexander mixed up the model with another one. :smileysmileywink:
When you're trying to remove this part the first time it can sit very tightly and be a bit tricky to remove. But yes, you can remove this cap so you can add a wrist strap to the phone.
4 REPLIES 4
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2013
September 2013
You are not suppose to remove the bottom cap of Xperia E.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2013
September 2013
Dear SONY the startup guid shows clearly how to do it with pictures , to attach the lanyard i attached it after removing the cap but it wasnt easy though!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2013
September 2013
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
September 2013
