Hello,
The XPeria E White Paper of december 2012 says, page 12, that EAP-SIM is supported for WiFi connections on this smartphone. However, I have this phone (bare, not linked to any operator, not simlocked), and there is no SIM option in the EAP section of WiFi security. What can I do to get it ?
Bonjour,
Le XPeria E White Paper de décembre 2012 stipule page 12 que l'EAP-SIM est pris en charge pour le WiFi sur ce smartphone. Cependant, j'en possède un (nu, pas lié à un opérateur, pas simlocké), et il n'y a pas l'option SIM dans la catégorie EAP de la sécurité WiFi. Comment dois-je faire pour en bénéficier ?
EAP-SIM is supported so that's very strange. Have you tried updating the phone using PC Companion? I have SIM as a selection under EAP method in my Xperia E running 11.3.A.2.13.
Hello,
I had totally forgotten that topic : indeed you're right, I had not done all the updates, and now that I'm up to date, the EAP-SIM option is available.
Thanks.
