hello,
my phone Xperia E3 restarts frequently and it shows " unfortunately camera common has stopped". even touch screen and power button is not responding. i am facing this problem since 2 days. could you please help me.
If it's still doing the same thing while in safe mode then I would recommend trying a software repair next.
even after i tried to boot my phone in safemode still it's showing me the message " Unfortunately camera common has stopped" and still the touch screen is not responding. please kindly help me if there is any other solution for this problem.
thank you very much
unfortunatey baack camra has stopped
plz reply me
Even i did master reset for 4 times in past one week through PC companion I am keep getting "unfortunately camera common has stopped" after one or two days from resetting the mobile.
Please help me
when I click on OK it keeps flashing the same error. using xperia E3.
Are you kidding? A lot of people with the problem, no solution trough Xperia Companion, you have to clear your phone twice a day. Spent half the price of my phone trying to fix it, still troubleing me. NEVER IN MY LIFE i'll buy these dishonest obsolete technology. Go Samsung or ASUS for a good phone.
Hi, have the same issue on my xperia e3. Software repair helps you to turn on your phone, but after few hours problem appears again - infinite alert unfortunately camera common has stopped then phone turns off and then goes to loop rebooting
