Hi everyone, my name is not malcolm but someone has my name as an alias! My Xperia E4g throw has stopped functioning altogether. Error messages appear all the time and I can't even access the throw settings menu to adjust anything. Software update doesn't help and resetting the device doesn't help either. Does anyone have a suggestion?
Hi @-Malcolm-,
I'm sorry to hear this. If I understood you correctly you have tried a factory reset and that didn't help? Have you also tried a software repair using PC Companion? If not then I would suggest that you try that with the help of a PC.
Hi @-Malcolm-,
Thanks for letting us know that the software repair fixed this for you though I'm sorry to hear that some of your contacts disappeared.
A backup in PC Companion only backs up the contacts that are saved locally in your phone, if they were synced with a Google account or similar service you need to add the same account again. I'd also suggest that you check the filters in the Contacts app, Contacts > tap the three dots > Filter > Show contacts, and enable all categories here. Might be that the contacts are there, just that they aren't visible.
