I used below anti viruses,
1. 360
2. AVG
3. Nortion
4.Bit defender
All of these make slown down my mobile working speed. mainly i can't view the contacts immediately once i tap the phone contact..
Can you pls Suggest a useful & compatiable antivirus for my mobile?
This is something debated very much and has been asked before.Antivirus is not needed as long as you keep installing from trusted sources (google play). They will slow down the device as you have already mentioned.
It has been asked before:
/t5/Xperia-E-E-dual/How-do-I-download-antivirus-for-my-Xperia-E/m-p/346884#M892
Thanks
Anytime.
