This has been on off over the month i have had the phone, it just randomly turns off. It usually happens when i have it in my pocket and has happened a couple of times when it gets knocked or something. Any soloutions?
I'm sorry to hear that the two of you are also experiencing this.
If this happens while using the camera application, is there any difference if you store your images to your SD-card compared to the internal storage? Are the shut downs still happening if you use the camera with your phone rebooted to safe mode?
Is there any change if you boot your phone without the SIM-card inserted? If your phone still shuts down during the booting process without the SIM-card inserted I would advise that you perform a software repair using Xperia Companion using a computer. Note that this will reset the phone but there is a feature in Xperia Companion that allows you to backup your phone.
Let me know how it goes!
Hi @Franny, I'm sorry to hear you are experiencing the same as everyone else in this thread. Have you tried the previous troubleshooting suggested here? Let me know if it helped or not.
and it was always the same. I tried to suppress some apps that I can't store in my memory card, desactivate some others and don't allow the automatic updates. but nevertheless the app update and continue working!! Very bad device 😥I'm in the same situation the phone worked just fine for a month , after that the problems started, the phone keeps turning itself off just randomly, now it doesn't charge the battery properly,I've already tried to remove the sim card and SD card without luck, and tried the companion option as well to reset the phone from factory settings .Do you guys think that there's going to be a soluton for this? otherwise the phone is still in warranty and i will request another brand if possible.
hi i had the same problem for like one weeks 5 times per day espacialy when it's in my pocket and now my phon is not responding for any thing!!
i got the phone like 2 months ago!
Hi i have the same problem and my phone have just 1 week!!! just switch off and on by im self!!!
Other problem is the camera of the phone dont take ages to make autofocus!!!!
I buy this one because i love the m2 i had !!!!
I just go to the shop to change for another mobile!!!!
My phone switches itself off every time I plug it in to charge - last night it actually charged to 100% but it did switch off. On monday night it switched itself off 7 times during a charge and stopped charging - I never got past 75% charge in 4 hours (battery was at 49% when I started) I really wanted to throw the phone out of the window - is this going to be fixed as looking at this forum there seems to be a lot of people in the same boat as me
