I have rooted my device using an online tool but now i am unable to see storage information and there is problem in updating or installing the new apps . what shoud i do now ?
Looks like something messed up your system when you rooted - you could try performing a system repair but I doubt that would work as you are rooted so your only other option would be to manually flash your phone using Flashtools and a .ftf firmware file
What did you use to root? and your apps if they are Sony apps like album etc may not update and it will detect your device as been modified
actually i wanted to uninstall the inbuilt apps so i rooted it. Now i am unable to install any app even not .apk file . Do you know what should i do now ?
i followed the procedure to unlock the bootloader given on this site . But after connecting to pc cmd keeps on showing "<waiting for device >" . How can i overcome from this ?
i tried that but cmd keeps on showing "waiting for device " while unlocking the bootloader . what should i do now ?
Have you installed the Fastboot driver from the Fastboot folder on C; drive via Device manager?
No, i can't find fastboot bolder in C drive . could you please help ?
sorry , actually i have downloaded that and replaceed the original .inf file as mentioned on this site. this is not working
So have you checked to see if the driver is installed or not?
