@reResd, is your modem/router set to ipv4 or ipv6? I believe it will not work if it is ipv6.
Hi @reResd,
Go to Settings > Wifi > Options > Advanced. Is "Keep Wi-Fi on during sleep" set to "Always"?
Yes, my WiFi during sleep is "always" on. As said, mobile data gives me notifications, but WiFi doesn't, eve when I'm using my phone.
Just did some researching and apparently push notifications do not work on IPv4.
Just swapped to IPv6 6to4 and it works like a charm, THANK YOU!
