After updating my Xperia E1 on Android 4.4.2 (Kitkat) my Facebook App was automatically uninstalled. If I want to install the app from Google Play Store I get the Message "Incompatible Version" and the installation is aborted. I shut down my mobile, removed sim-card and battery put both in again and than started the phone again but that changed nothing. A repair over PC Companion failured also due to no available software. Can you help me? thanks a lot:smileysmileythumbsup:
Followed Geran's instructions and backed up everything to the SD card and then did a factory re-set. The facebook app was there when the phone started up again. And it still worked after restoring everything from the SD card. Thanks Geran.
What this? Why I am facing problem with my mobile for installing Facebook.
How can I get android 4.4.4 for my Xperia E1 (D2005) ?
