Hello i need to block a number but i need the pin2 code to do it but i don't know how to get the code as i never set one please can someone help
PIN2 code is usually found printed on your SIM card case or holder that came when you first purchased it. If you can find that case/holder then you'll need to contact your service provider and they'll help you with this issue.
