Translation via Google Translate:
I put the phone to charge, it turns on but does not charge and the charger works
Pongo el movil a cargar, se enciende pero no carga y el cargador funciona
I used Google Translate to find the meaning of your message. Kindly post your future questions/feedbacks in English so we can assist you, this is an English based forum.
Try different combinations of wall chargers and USB cables. If you still can't charge your phone, then it's time to contact your Local support.
