PC COMPANION problem
OPGELOST
tonyjaimy
Bezoeker
I'm trying to update my xperia e with pc companion
After download software it's shows "Switch off after 5 seconds connect to computer PRESS AND HOLD VOLUME DOWN KEY"
i did same but my phone not connected
So i can't update my phone software
Please anybody help me
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
tonyjaimy
Bezoeker
Windows 7
I did it several times but. Same error
Bekijk de oplossing in de community in het oorspronkelijke bericht
3 ANTWOORDEN 3
profile.country.RO.title
_alexdon_
Expert
What windows are you using? Repeat the process several times (connect with volume down).
alexdon
tonyjaimy
Bezoeker
Windows 7
_alexdon_
Expert
Could you try on another computer?
alexdon
