x
Not started Xperia E c1504 SS
SOLVED
vikonder
Visitor
Hi, all
Phone is switched off after the battery out.
Then, after connection  to power AC or USB, the display automaticly shows SONY for 1-2 seconds and then phone reboots again. When press the power ON button, NO vibration and a flashing red light.... :((((
What to do?
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Uliwooly
Expert
Connect the phone to a wall charger > press and hold power & volume up for 5 seconds > let it charge for  1 or 2 hours > after 1-2 hours try to turn it back on
1 REPLY 1
Uliwooly
Expert
