I'm not able to downlaod or update any apps on my Experia E1. It says that the internal stoage is full but I have an SD card and it doesnt say that I can switch the data over to it. I have deleted and stopped programs but that still doesnt work.
ive already tried to do that but it still doesnt work
Settings > storage > how much free space do you have available (internal storage)?
340 MB
Thought I'd clarify what the other poster was suggestion/indicating:
While you may not be able to install software apps on the SD card, very often your actual data such as music, photos etc can take up alot of phone storage. Those things can be saved to the SD card.
