Suddenly my card is not recognised. Es file Explorer only displays internal memory. I tried connecting to laptop but same problem. What should I do? Tried cleaning with micro fibre cloth. Nothing. Is there a fluid? Or is it too late.
Hi @Hank66,
I'm sorry to hear this. If none of your devices recognise your SD card there isn't much your can try. Have you tried a different SD card with your Xperia E5 to make sure it is reading the SD card correctly?
