Is there a way to move the clock on the lock screen? I have a picture on there but the clock is smack bang in the middle of the face. Quite annoying really.
Hi @scoobydoo2, apologies for the late reply.
I'm afraid it isn't currently possible to change the position of the clock on the lock screen. It is however possible to change the look of it. This can be done by tapping and holding your finger on the clock while on the lock screen. You can then swipe left/right to see the other options that are available. Some may take up less space then the default clock so you might be able to find a better fit for your lock screen.
Let me know if you have any further questions about this!
