x
headset not compatible
SOLVED
narayansrinivas
Visitor
I'm unable to attend calls with Headset that came with Xperia E3. Does anyone has this bug???. I have not enabled smart connect
Tags (1)
1 ACCEPTED SOLUTION
Accepted Solutions
Phy
Legend
Legend
You should contact your local Sony Xperia Support
http://support.sonymobile.com/global-en/contactUs/
9 REPLIES 9
profile.country.GB.title
Uliwooly
Expert
Phy
Legend
Legend
What if you boot on safe mode, if it's a third-party app acting up the headphones should work
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
Phy
Legend
Legend
You could repair your phone with PC Companion
http://support.sonymobile.com/gb/tools/pc-companion/
narayansrinivas
Visitor
My IC was changed for hanging problem.  I am not using any 3rd party apps for headset.  And when I play music through Walkman app, it keeps on stopping for a few seconds and resuming to play.  If you have any solution to this, please let me know.  I bought this phone just a couple of months back
Uliwooly
Expert
Repair your phone with PCC and report back
narayansrinivas
Visitor
Repaired my phone with PCC. Still the headset is not compatible. When I press the answer key in the the headset, the incoming call gets rejected. And when I press that key in during idle time, the phone volume gets muted. Your comments on this
Phy
Legend
Legend
narayansrinivas
Visitor
I got replaced with new headset. Working fine now
Phy
Legend
Legend
Nice. Good to hear.
