all notification light greeen red pink yellow light up while charging.....repaired through pc companion once....still same ......after reaching 90% it goes green only.....any fix....or is this normal?
instead of yellow all colours light up.....did pcc repair once
Can you please elaborate, I'm not really following what you are explaining.
When charging the notification light should light red when you have low battery, yellow when you have medim battery and then green when you are around 90%.
mine has the same issue all lights red yellow green !!! when u see at different angles all are there!
This seems to be the case. I will pass this feedback on internally.
