With "call forward" or "call barring" de-activated in the Call Setting, the phone rings but I can not answer the call. Have reset the phone twice, it works properly for a while but then goes back to ring without the possibility of answering. What could be the cause? Have tried same Sim card in another phone, and it works properly. So it is something to do with the phone.
Topic edited by Rickard
Also check so that you haven't disabled any notifications under Settings -> Personalization -> Manage notificatios -> All. If InCallUI is disabled you will not be able to answer.
Glad to hear that it works now
Regarding your other question, the PIN the phone is asking for is the PIN2 for your SIM. However, not all operators allows you to change these settings from the phone. The settings you see in this menu are not really settings in the phone but settings in your subscription. When you change them the phone sends a command to your operator to change these settings in your subscription but as not all operators allows this you may need to contact your operator to have them changed.
