- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
in call block menu there are options for blocking all outgoing calls or all incoming calls. how to block any specific individual number?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To block a specific number from calling you, save the number as a contact and while you create/edit that contact you should have an option to always send it to voicemail under [menu].
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Other than the above,you can download apps from google play.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi ca8erpillar,
I have heard that Calls Blacklist is a good app to try. however you use these apps at your own risk.
I hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
thank you!
