In my alarm (default clock application) I set an auto silent time to 5 minutes...
But the alarm DON'T stop.
For ex. when driving it's realy a problem having this phone endlessly ringing (and much more in bed)
Can we auto stop this alarm ?
It should stop after said time but then after another set time sound the alarm again until you turn it off
Hi @pv2
I suggest boot your device into safe mode and check if this issue persits. If everything works ok in this mode, a third party app is creating this problem. I´m at disposal for any question.
Indeed, the alarm don't stop (maybe until battery is dead?)... unless you open the app and drag the slider.
Even with a auto silent time, the alarm restarts ringing after.
I have the same problem (I got my phone around 1 year ago)
Whatever settings(auto silent time and snooze duaration), it stops and repeats ringing for ever.
Is that means there no solution ?
Hi - what was the solution for this problem - as the threat is marked as " SOLVED " ?
I have the same problem - and would like to know how to solve it.
THX
What an utterly worthless thread. for the op, and others looking for solutions.
