Good morning , because the xperia e4 detected puts 4 fingers , but actually detect Now Detects reason 5 for 5 for an upgrade or because information about the 4 esta erroneous ? please do not lower it to 4 if it was updated 5
I forgive my English , but I speak Spanish
There's a glitch with that app, check this out
www-support-downloads.sonymobile.com/e2105/whitepaper_EN_e2104_e2105_xperia_e4.pdf
I think it's not a glich , according to box my xperia is the rev2 , according to e read some xperia e4 have problems with touch when playing or writing, rev2 and seen none has that ruling , till the test one mediamark detect five fingers, I detected any application 5, and 5 randomly moving them , any application that uses detects me 5 fingers , so my question is that on the web, and pdf 4 when said detecting detects 5 .
My concern is that we have the rev2 , we go down to 4 fingers and suffer the problem of touch
forgive my English I use google translator Spanish
Again, the info above comes from Sony's official white paper.
If it is , the paper says 4, but I ami detects 5 , you have the xperia e4 ? I commented that if it detects 5 rev2 deveria correct the information from the web as many people backing down when you buy if you have fewer fingers , but mostly for the accuracy
I don't understand your logic, the phone was not advertised as such (5 fingers).
where do you get this information? is it a fact or your opinion?
@thejavigames wrote:
... as many people backing down when you buy if you have fewer fingers ...
I do not understand if I guess not by the translator ,
e4 xperia itself as sensing 4 fingers .
but actually it detects 5, at least my xperia e4 and rev2 and those tested in stores.
http://www.gsmarena.com/sony_xperia_e4-6882.php
Four fingers , my xperia e4 detects 5 .
I ask that because it puts 4 if indeed detected 5, have a xperia e4 to prove ? that rev you?
I've escalated this and you will get an official statement, again, its on the white paper, I'm trying to help you here there's no need to antagonize me, I just want to know where do you get this info:
I will try to explain as best as possible ,
Many people believe that the more forums fingers is more accurately detected in many videos playing touch failures for example gta san andreas, blame the 4 fingers , I had a terminal 2 and worked detected only fatal to write fast .
at least seeing the comments on youtube and my experience with 2 fingers if it affects the sensitivity , only if you write fast by whatsapp , also it affects gestures google maps, although I guess it will be more quality tactile fingers .
ejemple:
https://www.youtube.com/watch?v=42adgBU80NI
coment acuse xperia,
https://www.youtube.com/watch?v=Eubv9ho8ULQ
ami me five fingers and detects these failures have not commenting on youtube and forums,
but I worry that sony back down to 4 fingers and the failures that have rev2 is by youtube.
I try to explain as best as possible not speak English
mi xperia detect 5 figers, no problem touch, you test 5 fingers or 4?
Hi thejavigames,
Sony Xperia E4 is designed and supported with multi-touch up to 4 fingers. I have tried the application that you've mentioned earlier and yes, it can in some cases detect 5 fingers but it doesn't work especially good. Therefore, we can only guarantee that it will work with multi-touch up to 4 fingers as stated in the white paper.
Hello, good ami me and I have no detects 5 errors , 5 moving works perfectly together .
