does anyone know of a camera that can be controlled by voice? Ideally with a decent zoom, touch screen and easy wireless transfer to a cloud [eg Google photos] does such a camera exist? Sony or any other brand?/
Hello @bee4bee,
there are certain action cams which you can at least start and stop the recording with your voice, but no camcorder with zoom and other professional features allows that.
- Nic
This is the THIRD time I have tried to respond to this post but they just don't appear!!!
Look up "Pluto Trigger", it may help you.
thnx for ur reply [and perseverance]. i'll look it up.
i'm looking for a voice controlled camera as i have extremely limited dexterity - i am unable to operate buttons, dials and any other fiddly controls. currently i'm using a samsung galaxy camera, which can be controlled by voice [zoom in/out, capture, take a video], it has a touchscreen and, being android-based, automatically backs up photos to google photos. it also has 21x optical zoom. however, it was released in 2012, the version of android is obsolete, every 2 weeks i have to restore the factory settings. i'm looking for a replacement, but have drawn a blank so far. a friend told me they'd seen a sony camera that has voice commands, but with the pandemic it's impossible to check it out in stores 😞
Ah now I understand. I'll join your search and let you know if I find anything for you.
Keep safe
