My Pinnacle Studio 14 can't find any movies taken on my new Sony HX7V, which are in HD.
What can I do ???
Hi jemadebo, welcome to the Sony Forums
I'm not really familiar with Pinnacle Studio; it may be that you'd get a quicker response on the Pinnacle support forums: http://forums.pinnaclesys.com/forums/70/ShowForum.aspx
Good luck
Mick
Good luck
Mick
