I have a problem with the quality of 4k video footage. Unsteady / flickering results in environments with a lot of sun. Especially bad in auto setting. Gets somewhat better with shutter priority with the following settings. XAVC S 4K - 25p 100M - shutter 1/50 auto ISO - auto WB.
Have also tried a variable ND KF True color 2-32 ND filter (with filter adapter from Filtermag). Still uneven and flickering result.
I hope someone can help.
I think I have figured out my uneven 4k result. Uses the following settings XAVC S 4K - 25p 100M - shutter 1/50 (180 degree rule) auto ISO - manual WB (removed much of the unevenness with the "correct" setting of WB) This with active use of the ND filter, it has become a good result. There are certainly opportunities for improvement, but it is just a matter of trying.
That is the joy of having photography / video as a hobby.
Thank you for your interest
Can you share an example with the issue?
Video must be displayed with 4K resolution. With 1K resolution, the error is not visible.
Not sure to understand where you see “flickering”.
I see a “choppy” video, that is why the 180 degree rule exists.
And you seen this in 4k res.?
Try to take a screenshot and draw a circle in the area where you see the fliker, it can help to understand
