I am thinking of buying the RX 100 m7 but without the shops being open I am unable to to try outing my hands I am keen to know I have the rear wheel size compares to that of the X350 which I find to be too small.
It's a little larger but not much.
I mad a size comparison picture for your reference:
thank you s much that was really useful to see the comparison
