I have a Cyber Shot DSC RX10 M4 and purchased an external flash HVL-F20M which is less powerful than I expected. I struggle with lighting and indoor shots. Any thoughts on the 'best' external flash please? The HVL-F43 M flash reads well i.e. superior power.
Usually (and it's the case) the number on the product name is also the guide number (GN) of the flash.
You can find the exact definition on internet, but here you have to know that it define the "power" of the flash.
Actually you have bought the smallest flash in sony product line, in terms of size AND power: GN20, really low.
If you pass from F20M to F43M you will have the double of the power.
The "standard" for professional use is from GN60 and highter, just to give you a size.
Many thanks Danardi78! That's what you get for a budget purchase ;o)
