Anyone having a problem with the lens on their Cybershot not extending or retracting properly might like to look at http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
I had a fault on my DSC-W170 which was solved by powering up the camera with the shutter button pressed (suggestion 4).
Hope this helps.
Thanks for sharing that information Mike.
It is for things like this that this forum was created. Thank you again for sharing.
