Just bought a HX20V don't think much of the Users Guide. Is there a more detailed guide that I can download and read at my leisure?
Hi Jephsha
The CyberShot User Guide is pretty in-depth, although it's HTML so you'll need a 'net connection to use it:
http://esupport.sony.com/docs/dvimag/DSCHX20V_HX30_HX30V_guide/en/index.html
Mick
Hi Jephsha
Mick
